HTTP ERROR 500
carl290
HTTP ERROR 500
Post by carl290 »
Hi,
I need to make some old software (BOONEX DOLPHIN v 7.3) work on a older version of MAMP, the 4.4
When I try to access the website I get :
"This page isn’t workinglocalhost is currently unable to handle this request.
HTTP ERROR 500"
On the php_error I get:
[30-May 202116:22:51 UTC] PHP Warning: file_get_contents(): php_network_getaddresses: getaddrinfo failed: nodename nor servname provided, or not known in /Applications/MAMP/bin/mamp/feed/fetchFeed.php on line 20
[30-May-2021 16:22:51 UTC] PHP Warning: file_get_contents(http://www.mamp.info/feed/mac/MAMP/English/feed/home.json): failed to open stream: php_network_getaddresses: getaddrinfo failed: nodename nor servname provided, or not known in /Applications/MAMP/bin/mamp/feed/fetchFeed.php on line 20
[30-May-2021 18:23:10 Europe/Amsterdam] PHP Fatal error: Uncaught Error: Call to undefined function set_magic_quotes_runtime() in /Applications/MAMP/htdocs/dcc/inc/header.inc.php:155
Stack trace:
#0 /Applications/MAMP/htdocs/dcc/index.php(25): require_once()
#1 {main}
thrown in /Applications/MAMP/htdocs/dcc/inc/header.inc.php on line 155
[30-May-2021 18:26:37 Europe/Amsterdam] PHP Fatal error: Uncaught Error: Call to undefined function set_magic_quotes_runtime() in /Applications/MAMP/htdocs/dcc/inc/header.inc.php:155
Stack trace:
#1 {main}
 thrown in /Applications/MAMP/htdocs/dcc/inc/header.inc.php on line 155"
What can be causing this?
thanks
Re: HTTP ERROR 500
