Newbie Error Code Question
Hi,
On a Mac with just installed MAMP trying to learn php. When I make a minor error, say forget the closing ; I get a general error:
This page isn’t working
localhost is currently unable to handle this request.
HTTP ERROR 500
Not sure where to go to generate more specific errors.
Tried adding some ini_set commands to set error_reporting(E_ALL) at the beginning of my first practice file with no Joy.
Do I need an htaccess file or what.
Everything was installed by defaults and error free code works fine.
HTTP ERROR 500
Re: Newbie Error Code Question
As of this moment I see 35 people have looked at this issue but none has offered any suggestions. For the moment whenever I get an error I upload to a server in the cloud and get the errors reported OK. This is not ideal and so if someone could point me in the right direction I would very much appreciate it.
Can you share your PHP error log?
Where do I find this PHP error log. No errors are reporting to the screen when I run the code.
Thanks for your response.
David
David
Finally did another search for this issue. Basically the MAMP supplied php.ini file comes with display_errors defaulted to Off.
One needs to find it and change it to On.
On my Mac, which took the default installation, it is located at:
Applications/MAMP/bin/php/php7.4.12/conf/php.ini
where the php version you are running can be found with phpinfo() and may differ from mine.
It seems this file has moved around quite a bit with the different versions.
Once the value is changed to ON be sure to cycle the MAMP server with STOP then START.
Now to keep learning PHP.......
