MAMP Pro on macOS Big Sur?
Has anyone had success running the latest version on Big Sur? Found this on StackIdeas since i guess it's not supported.
I updated the to MacOS Big Sur and then switched to MAMP Pro 6.3 from MAMP 4.x.
which php commands results the
usr/php/bin/
I updated the path using following. vim ~/.bash_profile
export PATH=/Applications/MAMP/bin/php/php7.4.12/bin:$PATH export PATH="$HOME/.yarn/bin:$HOME/.config/yarn/global/node_modules/.bin:$PATH"
Press esc and then :wq
source ~/.bash_profile
Now when I do which php it shows MAMP's php7.4.12 but if close and re-open the terminal, it again says
usr/php/bin
Btw, PHP 7.4.12 is set as Default version in MAMP Pro from PHP settings in MAMP Pro.
Versoins
macOS Big Sur version 11.1
MAMAP 6.3
