website's subpages are returning 404 errors in MAMP, home page works
EmD
Post by EmD »
I have read posts and articles about this issue but none of the solutions have worked for me. I copied a live site into MAMP and uploaded the existing database. The homepage displays properly in MAMP, but every subpage and /user results in a 404 error. Entering an admin URL DOES return the Access Denied page properly: http://produceavailable-drupal7.local/admin/reports/status
Below are all the things I have made changes to.
settings.php
$databases = array (
  'default' =>
  array (
    'default' =>
    array (
      'database' => 'produce7',
      'username' => 'root',
      'password' => 'root',
      'host' => 'localhost',
      'port' => '',
      'driver' => 'mysql',
      'prefix' => '',
terminal sudo vi /etc/hosts:
# Host Database
# localhost is used to configure the loopback interface
# when the system is booting.  Do not change this entry.
127.0.0.1       produceavailable-drupal7.local
127.0.0.1       localhost
255.255.255.255 broadcasthost
::1             localhost
httpd.conf
# This is the main Apache HTTP server configuration file.
ServerRoot "/Applications/MAMP/Library"
# PidFile: The file in which the server should record its process
# identification number when it starts.
<IfModule !mpm_netware.c>
PidFile logs/httpd.pid
</IfModule>
# Mutex: Allows you to set the mutex mechanism and mutex file directory
# for individual mutexes, or change the global defaults
# Uncomment and change the directory if mutexes are file-based and the default
# mutex file directory is not on a local disk or is not appropriate for some
# other reason.
# Mutex default:"/Applications/MAMP/Library/logs"
#Listen 12.34.56.78:80
Listen 80
# Dynamic Shared Object (DSO) Support
LoadModule access_compat_module modules/mod_access_compat.so
LoadModule actions_module modules/mod_actions.so
LoadModule alias_module modules/mod_alias.so
LoadModule allowmethods_module modules/mod_allowmethods.so
LoadModule auth_basic_module modules/mod_auth_basic.so
LoadModule auth_digest_module modules/mod_auth_digest.so
LoadModule auth_form_module modules/mod_auth_form.so
LoadModule authn_anon_module modules/mod_authn_anon.so
LoadModule authn_core_module modules/mod_authn_core.so
LoadModule authn_dbd_module modules/mod_authn_dbd.so
LoadModule authn_dbm_module modules/mod_authn_dbm.so
LoadModule authn_file_module modules/mod_authn_file.so
LoadModule authn_socache_module modules/mod_authn_socache.so
LoadModule authz_core_module modules/mod_authz_core.so
LoadModule authz_dbd_module modules/mod_authz_dbd.so
LoadModule authz_dbm_module modules/mod_authz_dbm.so
LoadModule authz_groupfile_module modules/mod_authz_groupfile.so
LoadModule authz_host_module modules/mod_authz_host.so
LoadModule authz_owner_module modules/mod_authz_owner.so
LoadModule authz_user_module modules/mod_authz_user.so
LoadModule autoindex_module modules/mod_autoindex.so
LoadModule bucketeer_module modules/mod_bucketeer.so
LoadModule buffer_module modules/mod_buffer.so
LoadModule cache_module modules/mod_cache.so
LoadModule case_filter_in_module modules/mod_case_filter_in.so
LoadModule case_filter_module modules/mod_case_filter.so
LoadModule cern_meta_module modules/mod_cern_meta.so
LoadModule cgi_module modules/mod_cgi.so
LoadModule cgid_module modules/mod_cgid.so
LoadModule charset_lite_module modules/mod_charset_lite.so
LoadModule dav_module modules/mod_dav.so
LoadModule dbd_module modules/mod_dbd.so
LoadModule deflate_module modules/mod_deflate.so
LoadModule dir_module modules/mod_dir.so
LoadModule dumpio_module modules/mod_dumpio.so
LoadModule echo_module modules/mod_echo.so
LoadModule env_module modules/mod_env.so
LoadModule expires_module modules/mod_expires.so
LoadModule ext_filter_module modules/mod_ext_filter.so
LoadModule fastcgi_module modules/mod_fastcgi.so
LoadModule file_cache_module modules/mod_file_cache.so
LoadModule filter_module modules/mod_filter.so
LoadModule headers_module modules/mod_headers.so
LoadModule http2_module modules/mod_http2.so
LoadModule include_module modules/mod_include.so
LoadModule info_module modules/mod_info.so
LoadModule lbmethod_bybusyness_module modules/mod_lbmethod_bybusyness.so
LoadModule lbmethod_byrequests_module modules/mod_lbmethod_byrequests.so
LoadModule lbmethod_bytraffic_module modules/mod_lbmethod_bytraffic.so
#LoadModule lbmethod_heartbeat_module modules/mod_lbmethod_heartbeat.so
LoadModule log_config_module modules/mod_log_config.so
LoadModule log_debug_module modules/mod_log_debug.so
LoadModule logio_module modules/mod_logio.so
LoadModule macro_module modules/mod_macro.so
LoadModule mime_magic_module modules/mod_mime_magic.so
LoadModule mime_module modules/mod_mime.so
LoadModule negotiation_module modules/mod_negotiation.so
LoadModule perl_module modules/mod_perl.so
LoadModule proxy_module modules/mod_proxy.so
LoadModule ratelimit_module modules/mod_ratelimit.so
LoadModule remoteip_module modules/mod_remoteip.so
LoadModule reqtimeout_module modules/mod_reqtimeout.so
LoadModule request_module modules/mod_request.so
LoadModule rewrite_module modules/mod_rewrite.so
LoadModule sed_module modules/mod_sed.so
LoadModule session_module modules/mod_session.so
LoadModule setenvif_module modules/mod_setenvif.so
LoadModule slotmem_shm_module modules/mod_slotmem_shm.so
LoadModule socache_dbm_module modules/mod_socache_dbm.so
LoadModule socache_memcache_module modules/mod_socache_memcache.so
LoadModule socache_shmcb_module modules/mod_socache_shmcb.so
LoadModule speling_module modules/mod_speling.so
# Starting v5.7 ssl_module is statically compiled into Apache and
# doesn't need to be enabled / can not be disabled.
LoadModule status_module modules/mod_status.so
LoadModule substitute_module modules/mod_substitute.so
#LoadModule unique_id_module modules/mod_unique_id.so
LoadModule unixd_module modules/mod_unixd.so
LoadModule userdir_module modules/mod_userdir.so
LoadModule usertrack_module modules/mod_usertrack.so
LoadModule version_module modules/mod_version.so
LoadModule vhost_alias_module modules/mod_vhost_alias.so
LoadModule watchdog_module modules/mod_watchdog.so
LoadModule wsgi_module modules/mod_wsgi.so
LoadModule xsendfile_module modules/mod_xsendfile.so
LoadModule php5_module        /Applications/MAMP/bin/php/php5.6.40/modules/libphp5.so
AddType application/x-httpd-php .php .phtml
<IfModule unixd_module>
# If you wish httpd to run as a different user or group, you must run
# httpd as root initially and it will switch.
# User/Group: The name (or #number) of the user/group to run httpd as.
# It is usually good practice to create a dedicated user and group for
# running httpd, as with most system services.
User emd2020
Group #-1
</IfModule>
<IfModule xsendfile_module>
    XSendFile on
</IfModule>
# 'Main' server configuration
# ServerAdmin: Your address, where problems with the server should be
# e-mailed.  This address appears on some server-generated pages, such
# as error documents.  e.g. [email protected]
ServerAdmin [email protected]
ServerName localhost:80
# MAMP DOCUMENT_ROOT !! Don't remove this line !!
DocumentRoot "/Applications/MAMP/htdocs"
# Each directory to which Apache has access can be configured with respect
# to which services and features are allowed and/or disabled in that
# directory (and its subdirectories).
# First, we configure the "default" to be a very restrictive set of
# features.
<Directory />
    Options Indexes FollowSymLinks
    AllowOverride All
</Directory>
# Note that from this point forward you must specifically allow
# particular features to be enabled - so if something's not working as
# you might expect, make sure that you have specifically enabled it
# below.
# This should be changed to whatever you set DocumentRoot to.
<Directory "/Applications/MAMP/htdocs">
    # Possible values for the Options directive are "None", "All",
    # or any combination of:
    #   Indexes Includes FollowSymLinks SymLinksifOwnerMatch ExecCGI MultiViews
    # Note that "MultiViews" must be named *explicitly* --- "Options All"
    # doesn't give it to you.
    # The Options directive is both complicated and important.  Please see
    # http://httpd.apache.org/docs/2.4/mod/core.html#options
    # for more information.
    Options All
    # AllowOverride controls what directives may be placed in .htaccess files.
    # It can be "All", "None", or any combination of the keywords:
    #   AllowOverride FileInfo AuthConfig Limit
    AllowOverride All
    # Controls who can get stuff from this server.
    Require all granted
    XSendFilePath "/Applications/MAMP/htdocs"
</Directory>
# DirectoryIndex: sets the file that Apache will serve if a directory
# is requested.
<IfModule dir_module>
    DirectoryIndex index.html index.php
    <IfModule perl_module>
        DirectoryIndex index.pl
    </IfModule>
    <IfModule wsgi_module>
        DirectoryIndex index.wsgi index.py
    </IfModule>
</IfModule>
# AccessFileName: The name of the file to look for in each directory
# for additional configuration directives.  See also the AllowOverride
# directive.
AccessFileName .htaccess
# The following lines prevent .htaccess and .htpasswd files from being
# viewed by Web clients.
<FilesMatch "^\.ht">
    Require all denied
    Satisfy All
</FilesMatch>
<Files ~ "^\.DS_Store">
    Require all denied
</Files>
# ErrorLog: The location of the error log file.
ErrorLog "/Applications/MAMP/logs/apache_error.log"
# LogLevel: Control the number of messages logged to the error_log.
# Possible values include: debug, info, notice, warn, error, crit,
# alert, emerg.
LogLevel error
<IfModule log_config_module>
    # The following directives define some format nicknames for use with
    # a CustomLog directive (see below).
    LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\"" combined
    LogFormat "%h %l %u %t \"%r\" %>s %b" common
    <IfModule logio_module>
      # You need to enable mod_logio.c to use %I and %O
      LogFormat "%h %l %u %t \"%r\" %>s %b \"%{Referer}i\" \"%{User-Agent}i\" %I %O" combinedio
    </IfModule>
    # The location and format of the access logfile (Common Logfile Format).
    CustomLog "/Applications/MAMP/logs/apache_access.log" combined
</IfModule>
<IfModule alias_module>
    # Alias: Maps web paths into filesystem paths and is used to
    # access content that does not live under the DocumentRoot.
    # Example:
    # Alias /webpath /full/filesystem/path
    # If you include a trailing / on /webpath then the server will
    # require it to be present in the URL.  You will also likely
    # need to provide a <Directory> section to allow access to
    # the filesystem path.
    # We include the /icons/ alias for FancyIndexed directory listings.  If you
    # do not use FancyIndexing, you may comment this out.
    Alias /favicon.ico "/Applications/MAMP/bin/favicon.ico"
    Alias /icons/ "/Applications/MAMP/Library/icons/"
    <Directory "/Applications/MAMP/Library/icons">
        Options Indexes MultiViews
        AllowOverride None
        Require all granted
    </Directory>
    Alias /phpMyAdmin "/Applications/MAMP/bin/phpMyAdmin"
    Alias /phpmyadmin "/Applications/MAMP/bin/phpMyAdmin"
    <Directory "/Applications/MAMP/bin/phpMyAdmin">
        AllowOverride None
        Require all granted
    </Directory>
    Alias /phpPgAdmin "/Applications/MAMP/bin/phpPgAdmin"
    Alias /phppgadmin "/Applications/MAMP/bin/phpPgAdmin"
    <Directory "/Applications/MAMP/bin/phpPgAdmin">
        AllowOverride None
        Require all granted
    </Directory>
    Alias /phpLiteAdmin "/Applications/MAMP/bin/phpLiteAdmin"
    Alias /phpliteadmin "/Applications/MAMP/bin/phpLiteAdmin"
    <Directory "/Applications/MAMP/bin/phpLiteAdmin">
        AllowOverride None
        Require all granted
    </Directory>
    Alias /MAMP "/Applications/MAMP/bin/mamp"
    <Directory "/Applications/MAMP/bin/mamp">
        AllowOverride None
        Require all granted
    </Directory>
    Alias /adminer "/Applications/MAMP/bin/adminer"
    <Directory "/Applications/MAMP/bin/adminer">
        DirectoryIndex adminer.php
        AllowOverride None
        Require all granted
    </Directory>
    # ScriptAlias: This controls which directories contain server scripts.
    ScriptAlias /cgi-bin/ "/Applications/MAMP/cgi-bin/"
    Alias /perl/ "/Applications/MAMP/cgi-bin/"
        PerlModule ModPerl::Registry
        <Location /perl>
            SetHandler perl-script
            PerlResponseHandler ModPerl::Registry
            PerlOptions +ParseHeaders
            Options +ExecCGI
        </Location>
    </IfModule>
</IfModule>
<IfModule cgid_module>
    # ScriptSock: On threaded servers, designate the path to the UNIX
    # socket used to communicate with the CGI daemon of mod_cgid.
    #Scriptsock logs/cgisock
</IfModule>
# "/Applications/MAMP/cgi-bin" should be changed to whatever your ScriptAliased
# CGI directory exists, if you have that configured.
<Directory "/Applications/MAMP/cgi-bin">
    AllowOverride None
    Options None
    Require all granted
</Directory>
<IfModule headers_module>
    # Avoid passing HTTP_PROXY environment to CGI's on this or any proxied
    # backend servers which have lingering "httpoxy" defects.
    # 'Proxy' request header is undefined by the IETF, not listed by IANA
    RequestHeader unset Proxy early
</IfModule>
# DefaultType: the default MIME type the server will use for a document
# if it cannot otherwise determine one, such as from filename extensions.
# If your server contains mostly text or HTML documents, "text/plain" is
# a good value.  If most of your content is binary, such as applications
# or images, you may want to use "application/octet-stream" instead to
# keep browsers from trying to display binary files as though they are
# text.
DefaultType text/plain
<IfModule mime_module>
    # TypesConfig points to the file containing the list of mappings from
    # filename extension to MIME-type.
    TypesConfig /Applications/MAMP/conf/apache/mime.types
    # AddType allows you to add to or override the MIME configuration
    # file specified in TypesConfig for specific file types.
    #AddType application/x-gzip .tgz
    # AddEncoding allows you to have certain browsers uncompress
    # information on the fly. Note: Not all browsers support this.
    #AddEncoding x-compress .Z
    #AddEncoding x-gzip .gz .tgz
    # If the AddEncoding directives above are commented-out, then you
    # probably should define those extensions to indicate media types:
    AddType application/x-compress .Z
    AddType application/x-gzip .gz .tgz
    # AddHandler allows you to map certain file extensions to "handlers":
    # actions unrelated to filetype. These can be either built into the server
    # or added with the Action directive (see below)
    # To use CGI scripts outside of ScriptAliased directories:
    # (You will also need to add "ExecCGI" to the "Options" directive.)
    AddHandler cgi-script .cgi .pl
    # For type maps (negotiated resources):
    #AddHandler type-map var
    # Filters allow you to process content before it is sent to the client.
    # To parse .shtml files for server-side includes (SSI):
    # (You will also need to add "Includes" to the "Options" directive.)
    #AddType text/html .shtml
    #AddOutputFilter INCLUDES .shtml
</IfModule>
# The mod_mime_magic module allows the server to use various hints from the
# contents of the file itself to determine its type.  The MIMEMagicFile
# directive tells the module where the hint definitions are located.
<IfModule mime_magic_module>
    MIMEMagicFile /Applications/MAMP/conf/apache/magic
</IfModule>
# Customizable error responses come in three flavors:
# 1) plain text 2) local redirects 3) external redirects
# Some examples:
#ErrorDocument 500 "The server made a boo boo."
#ErrorDocument 404 /missing.html
#ErrorDocument 404 "/cgi-bin/missing_handler.pl"
#ErrorDocument 402 http://www.example.com/subscription_info.html
# MaxRanges: Maximum number of Ranges in a request before
# returning the entire resource, or one of the special
# values 'default', 'none' or 'unlimited'.
# Default setting is to accept 200 Ranges.
#MaxRanges unlimited
# EnableMMAP and EnableSendfile: On systems that support it,
# memory-mapping or the sendfile syscall may be used to deliver
# files.  This usually improves server performance, but must
# be turned off when serving from networked-mounted
# filesystems or if support for these functions is otherwise
# broken on your system.
# Defaults: EnableMMAP On, EnableSendfile Off
#EnableMMAP off
#EnableSendfile off
# Supplemental configuration
# The configuration files in the /Applications/MAMP/conf/apache/extra/ directory can be
# included to add extra features or to modify the default configuration of
# the server, or you may simply copy their contents here and change as
# necessary.
# Server-pool management (MPM specific)
#Include /Applications/MAMP/conf/apache/extra/httpd-mpm.conf
# Multi-language error messages
#Include /Applications/MAMP/conf/apache/extra/httpd-multilang-errordoc.conf
# Fancy directory listings
#Include /Applications/MAMP/conf/apache/extra/httpd-autoindex.conf
# Language settings
#Include /Applications/MAMP/conf/apache/extra/httpd-languages.conf
# User home directories
#Include /Applications/MAMP/conf/apache/extra/httpd-userdir.conf
# Real-time info on requests and configuration
#Include /Applications/MAMP/conf/apache/extra/httpd-info.conf
# Virtual hosts
Include /Applications/MAMP/conf/apache/extra/httpd-vhosts.conf
# Local access to the Apache HTTP Server Manual
#Include /Applications/MAMP/conf/apache/extra/httpd-manual.conf
# Distributed authoring and versioning (WebDAV)
#Include /Applications/MAMP/conf/apache/extra/httpd-dav.conf
# Various default settings
#Include /Applications/MAMP/conf/apache/extra/httpd-default.conf
# Secure (SSL/TLS) connections
#Include /Applications/MAMP/conf/apache/extra/httpd-ssl.conf
# Note: The following must must be present to support
#       starting without SSL on platforms with no /dev/random equivalent
#       but a statically compiled-in mod_ssl.
<IfModule ssl_module>
SSLRandomSeed startup file:/dev/urandom 1024
SSLRandomSeed connect file:/dev/urandom 1024
# Uncomment the next line if Apache should not accept SSLv3 connections, to learn more google for "POODLE SSLv3".
# SSLProtocol All -SSLv2 -SSLv3
</IfModule>
httpd-vhosts.conf
# Virtual Hosts
# Required modules: mod_log_config
# If you want to maintain multiple domains/hostnames on your
# machine you can setup VirtualHost containers for them. Most configurations
# use only name-based virtual hosts so the server doesn't need to worry about
# IP addresses. This is indicated by the asterisks in the directives below.
# Please see the documentation at
# <URL:http://httpd.apache.org/docs/2.4/vhosts/>
# for further details before you try to setup virtual hosts.
# You may use the command line option '-S' to verify your virtual host
# configuration.
# Use name-based virtual hosting.
NameVirtualHost *:80
# VirtualHost example:
# Almost any Apache directive may go into a VirtualHost container.
# The first VirtualHost section is used for all requests that do not
# match a ServerName or ServerAlias in any <VirtualHost> block.
<VirtualHost *:80>
</VirtualHost>
<VirtualHost *:80>
    DocumentRoot "/Users/emd2020/Sites/produceavailable-drupal7"
    ServerName produceavailable-drupal7.local
</VirtualHost>
.htaccess
# Apache/PHP/Drupal settings:
# Protect files and directories from prying eyes.
<FilesMatch "\.(engine|inc|info|install|make|module|profile|test|po|sh|.*sql|theme|tpl(\.php)?|xtmpl)(~|\.sw[op]|\.bak|\.orig|\.save)?$|^(\.(?!well-known).*|Entries.*|Repository|Root|Tag|Template|composer\.(json|lock)|web\.config)$|^#.*#$|\.php(~|\.sw[op]|\.bak|\.orig\.save)$">
  <IfModule mod_authz_core.c>
    Require all denied
  </IfModule>
  <IfModule !mod_authz_core.c>
    Order allow,deny
  </IfModule>
</FilesMatch>
# Don't show directory listings for URLs which map to a directory.
Options -Indexes
# Follow symbolic links in this directory.
Options +FollowSymLinks
# Make Drupal handle any 404 errors.
ErrorDocument 404 /index.php
# Set the default handler.
DirectoryIndex index.php index.html index.htm
# Override PHP settings that cannot be changed at runtime. See
# sites/default/default.settings.php and drupal_environment_initialize() in
# includes/bootstrap.inc for settings that can be changed at runtime.
# PHP 5, Apache 1 and 2.
<IfModule mod_php5.c>
  php_flag magic_quotes_gpc                 off
  php_flag magic_quotes_sybase              off
  php_flag register_globals                 off
  php_flag session.auto_start               off
  php_value mbstring.http_input             pass
  php_value mbstring.http_output            pass
  php_flag mbstring.encoding_translation    off
</IfModule>
# Requires mod_expires to be enabled.
<IfModule mod_expires.c>
  # Enable expirations.
  ExpiresActive On
  # Cache all files for 2 weeks after access (A).
  ExpiresDefault A1209600
  <FilesMatch \.php$>
    # Do not allow PHP scripts to be cached unless they explicitly send cache
    # headers themselves. Otherwise all scripts would have to overwrite the
    # headers set by mod_expires if they want another caching behavior. This may
    # fail if an error occurs early in the bootstrap process, and it may cause
    # problems if a non-Drupal PHP file is installed in a subdirectory.
    ExpiresActive Off
  </FilesMatch>
</IfModule>
# Various rewrite rules.
<IfModule mod_rewrite.c>
  RewriteEngine on
  # Set "protossl" to "s" if we were accessed via https://.  This is used later
  # if you enable "www." stripping or enforcement, in order to ensure that
  # you don't bounce between http and https.
  RewriteRule ^ - [E=protossl]
  RewriteCond %{HTTPS} on
  RewriteRule ^ - [E=protossl:s]
  # Make sure Authorization HTTP header is available to PHP
  # even when running as CGI or FastCGI.
  RewriteRule ^ - [E=HTTP_AUTHORIZATION:%{HTTP:Authorization}]
  # Block access to "hidden" directories whose names begin with a period. This
  # includes directories used by version control systems such as Subversion or
  # Git to store control files. Files whose names begin with a period, as well
  # as the control files used by CVS, are protected by the FilesMatch directive
  # above.
  # NOTE: This only works when mod_rewrite is loaded. Without mod_rewrite, it is
  # not possible to block access to entire directories from .htaccess, because
  # <DirectoryMatch> is not allowed here.
  # If you do not have mod_rewrite installed, you should remove these
  # directories from your webroot or otherwise protect them from being
  # downloaded.
  RewriteRule "/\.|^\.(?!well-known/)" - [F]
  # If your site can be accessed both with and without the 'www.' prefix, you
  # can use one of the following settings to redirect users to your preferred
  # URL, either WITH or WITHOUT the 'www.' prefix. Choose ONLY one option:
  # To redirect all users to access the site WITH the 'www.' prefix,
  # (http://example.com/... will be redirected to http://www.example.com/...)
  # uncomment the following:
  # RewriteCond %{HTTP_HOST} .
  # RewriteCond %{HTTP_HOST} !^www\. [NC]
  # RewriteRule ^ http%{ENV:protossl}://www.%{HTTP_HOST}%{REQUEST_URI} [L,R=301]
  # To redirect all users to access the site WITHOUT the 'www.' prefix,
  # (http://www.example.com/... will be redirected to http://example.com/...)
  # RewriteCond %{HTTP_HOST} ^www\.(.+)$ [NC]
  # RewriteRule ^ http%{ENV:protossl}://%1%{REQUEST_URI} [L,R=301]
  # Modify the RewriteBase if you are using Drupal in a subdirectory or in a
  # VirtualDocumentRoot and the rewrite rules are not working properly.
  # For example if your site is at http://example.com/drupal uncomment and
  # modify the following line:
  # RewriteBase /drupal
  # If your site is running in a VirtualDocumentRoot at http://example.com/,
  # uncomment the following line:
  # RewriteBase /
  # Pass all requests not referring directly to files in the filesystem to
  # index.php. Clean URLs are handled in drupal_environment_initialize().
  RewriteCond %{REQUEST_FILENAME} !-f
  RewriteCond %{REQUEST_FILENAME} !-d
  RewriteCond %{REQUEST_URI} !=/favicon.ico
  RewriteRule ^ index.php [L]
  # Rules to correctly serve gzip compressed CSS and JS files.
  # Requires both mod_rewrite and mod_headers to be enabled.
  <IfModule mod_headers.c>
    # Serve gzip compressed CSS files if they exist and the client accepts gzip.
    RewriteCond %{HTTP:Accept-encoding} gzip
    RewriteCond %{REQUEST_FILENAME}\.gz -s
    RewriteRule ^(.*)\.css $1\.css\.gz [QSA]
    # Serve gzip compressed JS files if they exist and the client accepts gzip.
    RewriteRule ^(.*)\.js $1\.js\.gz [QSA]
    # Serve correct content types, and prevent mod_deflate double gzip.
    RewriteRule \.css\.gz$ - [T=text/css,E=no-gzip:1]
    RewriteRule \.js\.gz$ - [T=text/javascript,E=no-gzip:1]
    <FilesMatch "(\.js\.gz|\.css\.gz)$">
      # Serve correct encoding type.
      Header set Content-Encoding gzip
      # Force proxies to cache gzipped & non-gzipped css/js files separately.
      Header append Vary Accept-Encoding
    </FilesMatch>
  </IfModule>
</IfModule>
# Add headers to all responses.
  # Disable content sniffing, since it's an attack vector.
  Header always set X-Content-Type-Options nosniff
</IfModule>
Ports set to 80. Mysql port is 3306.
I'm not sure what else to try.
Re: website's subpages are returning 404 errors in MAMP, home page works
MAMP Pro for Mac? It's likely a permissions issue on the host folder preventing reading.
EmD
Post by EmD »
I have just MAMP, not MAMP Pro. Here is what Terminal reports. produceavailable-drupal7 is the one I'm trying to access:
-rwxr-xr-x@  1 emd2020  staff  323155 Feb  6 14:32 different-php-version.pages
drwxr-xr-x   3 emd2020  staff      96 Feb  1 09:55 localhost
drwxrwxr-x  33 emd2020  staff    1056 Feb  6 15:59 produceavailable-drupal7
-rw-r--r--@  1 emd2020  staff  115881 Nov 17 22:07 CHANGELOG.txt
-rw-r--r--@  1 emd2020  staff    1481 Nov 17 22:07 COPYRIGHT.txt
-rw-r--r--@  1 emd2020  staff    1717 Nov 17 22:07 INSTALL.mysql.txt
-rw-r--r--@  1 emd2020  staff    1874 Nov 17 22:07 INSTALL.pgsql.txt
-rw-r--r--@  1 emd2020  staff    1298 Nov 17 22:07 INSTALL.sqlite.txt
-rw-r--r--@  1 emd2020  staff   17995 Nov 17 22:07 INSTALL.txt
-rw-r--r--@  1 emd2020  staff   18092 Nov 16  2016 LICENSE.txt
-rw-r--r--@  1 emd2020  staff    8465 Nov 17 22:07 MAINTAINERS.txt
-rw-r--r--@  1 emd2020  staff    5382 Nov 17 22:07 README.txt
-rw-r--r--@  1 emd2020  staff   10123 Nov 17 22:07 UPGRADE.txt
-rw-r--r--@  1 emd2020  staff    6604 Nov 17 22:07 authorize.php
-rw-r--r--@  1 emd2020  staff     720 Nov 17 22:07 cron.php
drwxr-xr-x  51 emd2020  staff    1632 Feb  5 15:56 includes
-rw-r--r--@  1 emd2020  staff     529 Nov 17 22:07 index.php
-rw-r--r--@  1 emd2020  staff     703 Nov 17 22:07 install.php
drwxr-xr-x  76 emd2020  staff    2432 Feb  5 16:05 misc
drwxr-xr-x  43 emd2020  staff    1376 Feb  5 16:34 modules
-rw-r--r--@  1 emd2020  staff      20 Dec  2 13:52 phpinfo.php
drwxr-xr-x   6 emd2020  staff     192 Feb  5 16:35 profiles
-rw-r--r--@  1 emd2020  staff    2189 Nov 17 22:07 robots.txt
drwxr-xr-x  13 emd2020  staff     416 Feb  5 16:35 scripts
drwxr-xr-x   7 emd2020  staff     224 Feb  6 10:44 sites
drwxr-xr-x   8 emd2020  staff     256 Feb  5 17:57 themes
-rw-r--r--@  1 emd2020  staff   19986 Nov 17 22:07 update.php
-rw-r--r--@  1 emd2020  staff    2211 Nov 17 22:07 web.config
-rw-r--r--@  1 emd2020  staff     417 Nov 17 22:07 xmlrpc.php
Can you share what the Apache access/error logs are saying for the requests?
EmD
Post by EmD »
I understand none of this...
[Mon Feb 01 09:55:46.546867 2021] [:notice] [pid 1011] FastCGI: process manager initialized (pid 1011)
[Mon Feb 01 09:55:46.548078 2021] [mpm_prefork:notice] [pid 1009] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 01 09:55:46.548628 2021] [core:notice] [pid 1009] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd -f /Library/Application Support/appsolute/MAMP PRO/conf/httpd.conf'
[Mon Feb 01 10:02:14.592106 2021] [mpm_prefork:notice] [pid 1009] AH00169: caught SIGTERM, shutting down
[Mon Feb 01 10:17:44.991537 2021] [:notice] [pid 2380] FastCGI: process manager initialized (pid 2380)
[Mon Feb 01 10:17:44.993243 2021] [mpm_prefork:notice] [pid 2330] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 01 10:17:44.993559 2021] [core:notice] [pid 2330] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Mon Feb 01 11:59:39.972659 2021] [mpm_prefork:notice] [pid 2330] AH00171: Graceful restart requested, doing restart
[Mon Feb 01 11:59:45.160220 2021] [:notice] [pid 4251] FastCGI: process manager initialized (pid 4251)
[Mon Feb 01 11:59:45.160405 2021] [mpm_prefork:notice] [pid 2330] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 01 11:59:45.160962 2021] [core:notice] [pid 2330] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Mon Feb 01 12:49:22.901679 2021] [mpm_prefork:notice] [pid 2330] AH00169: caught SIGTERM, shutting down
[Mon Feb 01 13:07:29.681842 2021] [:notice] [pid 5305] FastCGI: process manager initialized (pid 5305)
[Mon Feb 01 13:07:29.687540 2021] [mpm_prefork:notice] [pid 5299] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 01 13:07:29.688017 2021] [core:notice] [pid 5299] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd -f /Library/Application Support/appsolute/MAMP PRO/conf/httpd.conf'
[Mon Feb 01 13:12:20.122222 2021] [mpm_prefork:notice] [pid 5299] AH00169: caught SIGTERM, shutting down
[Mon Feb 01 13:12:22.027833 2021] [:notice] [pid 6122] FastCGI: process manager initialized (pid 6122)
[Mon Feb 01 13:12:22.033070 2021] [mpm_prefork:notice] [pid 6116] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 01 13:12:22.033561 2021] [core:notice] [pid 6116] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd -f /Library/Application Support/appsolute/MAMP PRO/conf/httpd.conf'
[Mon Feb 01 14:50:41.584161 2021] [mpm_prefork:notice] [pid 6116] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 10:58:03.676464 2021] [:notice] [pid 1161] FastCGI: process manager initialized (pid 1161)
[Fri Feb 05 10:58:03.678070 2021] [mpm_prefork:notice] [pid 1110] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 10:58:03.678383 2021] [core:notice] [pid 1110] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:10:29.092564 2021] [mpm_prefork:notice] [pid 1110] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:10:39.876326 2021] [:notice] [pid 1687] FastCGI: process manager initialized (pid 1687)
[Fri Feb 05 11:10:39.878352 2021] [mpm_prefork:notice] [pid 1636] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:10:39.878788 2021] [core:notice] [pid 1636] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:24:46.446262 2021] [core:notice] [pid 1636] AH00052: child pid 1692 exit signal Abort trap (6)
[Fri Feb 05 11:24:46.513001 2021] [mpm_prefork:notice] [pid 1636] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:24:57.683337 2021] [:notice] [pid 2414] FastCGI: process manager initialized (pid 2414)
[Fri Feb 05 11:24:57.685334 2021] [mpm_prefork:notice] [pid 2363] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:24:57.685730 2021] [core:notice] [pid 2363] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:31:59.648525 2021] [mpm_prefork:notice] [pid 2363] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:32:10.304398 2021] [:notice] [pid 2864] FastCGI: process manager initialized (pid 2864)
[Fri Feb 05 11:32:10.306444 2021] [mpm_prefork:notice] [pid 2813] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:32:10.306812 2021] [core:notice] [pid 2813] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:32:38.061861 2021] [mpm_prefork:notice] [pid 2813] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:32:48.320643 2021] [:notice] [pid 3133] FastCGI: process manager initialized (pid 3133)
[Fri Feb 05 11:32:48.322714 2021] [mpm_prefork:notice] [pid 3082] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:32:48.323070 2021] [core:notice] [pid 3082] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:38:32.273503 2021] [mpm_prefork:notice] [pid 3082] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:38:42.880579 2021] [:notice] [pid 3559] FastCGI: process manager initialized (pid 3559)
[Fri Feb 05 11:38:42.882416 2021] [mpm_prefork:notice] [pid 3510] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:38:42.882698 2021] [core:notice] [pid 3510] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:41:42.115598 2021] [mpm_prefork:notice] [pid 3510] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:41:52.639092 2021] [:notice] [pid 3886] FastCGI: process manager initialized (pid 3886)
[Fri Feb 05 11:41:52.641088 2021] [mpm_prefork:notice] [pid 3835] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:41:52.641461 2021] [core:notice] [pid 3835] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:47:47.880274 2021] [mpm_prefork:notice] [pid 3835] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:47:58.431939 2021] [:notice] [pid 4309] FastCGI: process manager initialized (pid 4309)
[Fri Feb 05 11:47:58.434209 2021] [mpm_prefork:notice] [pid 4259] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:47:58.434606 2021] [core:notice] [pid 4259] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:49:13.835519 2021] [mpm_prefork:notice] [pid 4259] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:49:30.875615 2021] [:notice] [pid 4642] FastCGI: process manager initialized (pid 4642)
[Fri Feb 05 11:49:30.877779 2021] [mpm_prefork:notice] [pid 4590] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:49:30.878191 2021] [core:notice] [pid 4590] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:51:32.253569 2021] [mpm_prefork:notice] [pid 4590] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:51:42.741900 2021] [:notice] [pid 5056] FastCGI: process manager initialized (pid 5056)
[Fri Feb 05 11:51:42.743979 2021] [mpm_prefork:notice] [pid 5002] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:51:42.744381 2021] [core:notice] [pid 5002] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:54:42.422025 2021] [mpm_prefork:notice] [pid 5002] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:54:55.178668 2021] [:notice] [pid 5326] FastCGI: process manager initialized (pid 5326)
[Fri Feb 05 11:54:55.179190 2021] [mpm_prefork:notice] [pid 5300] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:54:55.179571 2021] [core:notice] [pid 5300] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 11:54:55.799087 2021] [mpm_prefork:notice] [pid 5300] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 11:56:48.857171 2021] [:notice] [pid 5560] FastCGI: process manager initialized (pid 5560)
[Fri Feb 05 11:56:48.857347 2021] [mpm_prefork:notice] [pid 5511] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 11:56:48.857768 2021] [core:notice] [pid 5511] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 12:43:10.258190 2021] [mpm_prefork:notice] [pid 5511] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 12:43:21.172947 2021] [:notice] [pid 6896] FastCGI: process manager initialized (pid 6896)
[Fri Feb 05 12:43:21.173735 2021] [mpm_prefork:notice] [pid 6844] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 12:43:21.174179 2021] [core:notice] [pid 6844] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Fri Feb 05 15:04:36.268586 2021] [mpm_prefork:notice] [pid 6844] AH00169: caught SIGTERM, shutting down
[Fri Feb 05 15:29:23.552168 2021] [:notice] [pid 8966] FastCGI: process manager initialized (pid 8966)
[Fri Feb 05 15:29:23.552346 2021] [mpm_prefork:notice] [pid 8915] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Fri Feb 05 15:29:23.552902 2021] [core:notice] [pid 8915] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 10:43:33.662999 2021] [mpm_prefork:notice] [pid 8915] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 10:43:45.489711 2021] [:notice] [pid 12920] FastCGI: process manager initialized (pid 12920)
[Sat Feb 06 10:43:45.490914 2021] [mpm_prefork:notice] [pid 12870] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 10:43:45.491295 2021] [core:notice] [pid 12870] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 10:45:45.363723 2021] [mpm_prefork:notice] [pid 12870] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 10:45:55.697397 2021] [:notice] [pid 13260] FastCGI: process manager initialized (pid 13260)
[Sat Feb 06 10:45:55.697856 2021] [mpm_prefork:notice] [pid 13209] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 10:45:55.698297 2021] [core:notice] [pid 13209] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 11:19:03.158590 2021] [mpm_prefork:notice] [pid 13209] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 11:19:13.776232 2021] [:notice] [pid 13967] FastCGI: process manager initialized (pid 13967)
[Sat Feb 06 11:19:13.777200 2021] [mpm_prefork:notice] [pid 13926] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/7.4.12 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 11:19:13.777674 2021] [core:notice] [pid 13926] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 11:19:44.188004 2021] [mpm_prefork:notice] [pid 13926] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 11:23:06.060314 2021] [:notice] [pid 14331] FastCGI: process manager initialized (pid 14331)
[Sat Feb 06 11:23:06.060377 2021] [mpm_prefork:notice] [pid 14280] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/5.6.40 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 11:23:06.060902 2021] [core:notice] [pid 14280] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 11:34:49.900328 2021] [mpm_prefork:notice] [pid 14280] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 11:35:15.358708 2021] [:notice] [pid 14938] FastCGI: process manager initialized (pid 14938)
[Sat Feb 06 11:35:15.358750 2021] [mpm_prefork:notice] [pid 14888] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/5.6.40 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 11:35:15.359199 2021] [core:notice] [pid 14888] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 12:16:06.668880 2021] [mpm_prefork:notice] [pid 14888] AH00169: caught SIGTERM, shutting down
[Sat Feb 06 12:16:31.816634 2021] [:notice] [pid 15666] FastCGI: process manager initialized (pid 15666)
[Sat Feb 06 12:16:31.816728 2021] [mpm_prefork:notice] [pid 15616] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/5.6.40 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Sat Feb 06 12:16:31.817197 2021] [core:notice] [pid 15616] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Sat Feb 06 21:56:13.807252 2021] [mpm_prefork:notice] [pid 15616] AH00169: caught SIGTERM, shutting down
[Mon Feb 08 09:05:53.163118 2021] [mpm_prefork:notice] [pid 920] AH00163: Apache/2.4.46 (Unix) OpenSSL/1.0.2u PHP/5.6.40 mod_wsgi/3.5 Python/2.7.13 mod_fastcgi/mod_fastcgi-SNAP-0910052141 mod_perl/2.0.11 Perl/v5.30.1 configured -- resuming normal operations
[Mon Feb 08 09:05:53.163131 2021] [:notice] [pid 971] FastCGI: process manager initialized (pid 971)
[Mon Feb 08 09:05:53.163754 2021] [core:notice] [pid 920] AH00094: Command line: '/Applications/MAMP/Library/bin/httpd'
[Mon Feb 08 21:26:32.790833 2021] [mpm_prefork:notice] [pid 920] AH00169: caught SIGTERM, shutting down
Your Apache isn't staying started. Are you seeing it on in MAMP when you try to browse?
I suspect you might have 2 Apache processes going (Mac's built-in process and then Mamp's). Check activity viewer.
EmD
Post by EmD »
mampsupportmod wrote: Wed Feb 10, 2021 12:11 pm Your Apache isn't staying started. Are you seeing it on in MAMP when you try to browse?
The start/stop button is always green so I can't tell that this is occurring. Can you tell me where the Activity Viewer is? When I look at my Mac I see Activity Monitor but it doesn't list MAMP or Apache.
Looking at other logs I see these errors in the php_error.log
[01-Feb-2021 14:00:01 America/Mexico_City] PHP Warning:  POST Content-Length of 10843648 bytes exceeds the limit of 8388608 bytes in Unknown on line 0
[06-Feb-2021 10:29:06 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
[06-Feb-2021 10:29:18 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
[06-Feb-2021 13:55:43 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
[06-Feb-2021 13:58:10 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
[06-Feb-2021 16:58:21 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
[08-Feb-2021 07:06:26 America/Los_Angeles] PHP Fatal error:  Cannot redeclare views_views_plugins() (previously declared in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/views/includes/plugins.inc:15) in /Users/emd2020/Sites/produceavailable-drupal7/sites/all/modules/unused/views/includes/plugins.inc on line 405
Yet the site works online.
kevin sean
Post by kevin sean »
I'm having the same problem. Did you use WP duplicator to install your sites like me?
I think it is a mod rewrite issue with Apache, that is that mod rewrite is turned off. I tried these solutions but none worked.
https://snapcreek.com/duplicator/docs/f ... ller-200-q
following
Kevin
gbouhier
Post by gbouhier »
Hello EmD,
I have the same issue with the same logs.
I am on a fresh new installation of mamp with virtual host. Did you manage to find a solution please ?
