Apache mod_fastcgi & HTTP/2 Inconsistencies
We were receiving below across our sites after enabling
http2_module
in Apache config:
411 Error:
Length Required
A request of the requested method GET requires a valid Content-length.
Apache/2.4.66 (Unix) OpenSSL/1.1.Iw mod_wsgil5.0.2 Python/3.14 mod_fastci/mod_fastgi-
411 Length Required
After investigation we found
mod_fastcgi
incompatibility with HTTP/2 and produces random 411 errors on browsing. However, current version of MAMP Pro requires FastCGI remain enabled per config:
# modules that SHOULD be always ON
LoadModule fastcgi_module modules/mod_fastcgi.so
mod_fastcgi is now considered legacy. MAMP needs to move to new version which is
http2_module
proxy_fcgi_module
and so to allow disabling of fastcgi.
Short term solution is to disable http2_module in Apache config when using fastcgi.
