why is it so tedious installing libssh2 libraries and getting them recognized by MAMP php? I still don't know if I've installed them properly. Does anyone know the best way to install these. I have to use sftp for an upload process with a vendor.
Thanks,
George
Difficulty installing libssh2 libraries
miaalexandra
Re: Difficulty installing libssh2 libraries
I have troubles installing mono develop. I was trying to follow this tutorial but I had an error when hitting this command I have troubles installing mono develop. I was trying to follow this tutorial but I had an error when hitting this command You should be able to install the package libssh2 in a terminal, just like any other package. It's available in Ubuntu's normal repos. why is it so tedious installing libssh2 libraries and getting them recognized by MAMP php? I still don't know if I've installed them ..You have to put that libssh2. dll somewhere on the %path% so then the PHP extension can find it. Logic were to put it into your PHP dir (if you use the standard zipball from windows
