Mongodb Extension MAMP Pro 5.7 - macOS 10.15.6 (Catalina) and PHP 7.3.9
I've been trying for days to set up a driver for the Mongodb under MAMP Pro 5.7 - macOS 10.15.6 and PHP 7.3.9.
I have followed these instructions:
https://documentation.mamp.info/en/MAMP ... eral/PECL/
Since macOS itself comes with PHP, running "phpize" apparently causes a conflict with the PHP driver that comes with MAMP. The problem is that "phpsize" returns this message:
% phpize -v
grep: /usr/include/php/main/php.h: No such file or directory
grep: /usr/include/php/Zend/zend_modules.h: No such file or directory
grep: /usr/include/php/Zend/zend_extensions.h: No such file or directory
Configuring for:
PHP Api Version:
Zend Module Api No:
Zend Extension Api No:
Have any of you ever solved this problem? How can I prevent "phpize" from being used by macOS? How can I force "phpize" to be used by MAMP instead?
