page with php ending not opening
mamper
Post by mamper »
Hi, using MAMP I have the issue of a page with index.php on localhost does not open (index.html works fine).
Instead, on a brand new WordPress installation, a file is downloaded:
<?php
 * Front to the WordPress application. This file doesn't do anything, but loads
 * wp-blog-header.php which does and tells WordPress to load the theme.
 * @package WordPress
 * Tells WordPress to load the WordPress theme and output it.
 * @var bool
define( 'WP_USE_THEMES', true );
/** Loads the WordPress Environment and Template */
require __DIR__ . '/wp-blog-header.php';
What might be the reason? (Mamp 6.8, MacBook Pro M2)
Thanks
mamper
Re: page with php ending not opening
Post by mamper »
Does nobody have an idea how I can solve this?
mamper
Post by mamper »
Looks like I won't be able to use MAMP ever again. I have no solution to this issue.
