HTTP 500 Error access phpMyAdmin on Mac Monterey
trstaley
Post by trstaley »
I bought a a new iMac and migrated my old iMac running Mohave OS to my new iMac which is running Monterey OS. My previous iMac had a fully functional MAMP Pro install.
My httpd.conf file is in the Library/appsolute/MAMP PRO/conf directory and set listen on port 80.
After migrating, I can launch MAMP Pro. Apache is running and all my databases are displayed. I am also able to launch my php app. However the app is not connecting to the database.
Using the terminal I can see that the databases are there and I can connect to a database and query tables with no issue.
When I go to Webstart in MAMP Pro and then attempt to launch phpMyAdmin, I get the following error:
This page isn’t working
localhost is currently unable to handle this request.
HTTP ERROR 500
Anyone have any suggestions for how to correct this issue?
Re: HTTP 500 Error access phpMyAdmin on Mac Monterey
Please share Apache/PHP/MySQL logs after getting the 500 error
trstaley
Post by trstaley »
I apologize for not doing so.
[28-Jul-2022 09:06:23 America/New_York] PHP Parse error: syntax error, unexpected 'use' (T_USE) in /Library/Application Support/appsolute/MAMP PRO/phpMyAdmin/index.php on line 11
I found the issue and it was a mistyped statement in the php file. My assumption was that it had to do with something else, and I missed checking the php error log.
Thank you for asking to attach the log files, as this caused me to re-look at them.
