The selected folder is a sub-folder of another host's document root...
I think there's a bug - selecting 2 hosts for same document root has never been an issue. In order to back out of this error message, you need to manually remove the host and re-add it.
The selected folder is a sub-folder of another host's document root ,or identical to another document root! This is not allowed.
Selected Folder Is A Sub Folder Root Mamp
Selected Folder Is A Sub Folder Root Mamp (19.92 KiB) Viewed 32778 times
stephangrass
Re: The selected folder is a sub-folder of another host's document root...
Post by stephangrass »
I don't understand how to bypass the error. Every time I want to add another host to an existing Document root, the error appears.
Can somebody give me a tip with that?
Thanks
Stephan
treehillstudio
Post by treehillstudio »
It is possible to use the same document root with multiple hostnames. This can be done via the "Aliases" option in the "General" section.
Unfortunately, I didn't get a tip in the right direction from MAMP PRO support or via a Google search.
