MAMP Pro php.ini Location (Latest)
Discussion for guides including MAMP official & unofficial documentation. User submitted guides can be moved here by moderators.
MAMP Pro stores the real php.ini configuration file (after you edit the template) in the following location.
/Library/application support/appsolute/MAMP PRO/conf
You can quickly access this location by Go menu -> Go To Folder.
