Mysql not starting. Please help!
Posted: Fri May 28, 2021 2:55 am
On a macbook pro with an m1 chip
MAMP Pro
MySql Error Log:
MAMP Pro
MySql Error Log:
2021-05-28T02:40:48.6NZ mysqld_safe mysqld from pid file /Applications/MAMP/tmp/mysql/mysql.pid ended
2021-05-28T02:44:15.6NZ mysqld_safe Logging to '/Applications/MAMP/logs/mysql_error.log'.
2021-05-28T02:44:15.6NZ mysqld_safe Starting mysqld daemon with databases from /Library/Application Support/appsolute/MAMP PRO/db/mysql57
2021-05-28T02:44:15.642970Z 0 [Warning] Insecure configuration for --secure-file-priv: Current value does not restrict location of generated files. Consider setting it to a valid, non-empty path.
2021-05-28T02:44:15.644305Z 0 [Note] /Applications/MAMP/Library/bin/mysqld (mysqld 5.7.32) starting as process 5857 ...
2021-05-28T02:44:15.654443Z 0 [Warning] Setting lower_case_table_names=2 because file system for /Library/Application Support/appsolute/MAMP PRO/db/mysql57/ is case insensitive
2021-05-28T02:44:15.661407Z 0 [Note] InnoDB: Mutexes and rw_locks use GCC atomic builtins
2021-05-28T02:44:15.661441Z 0 [Note] InnoDB: Uses event mutexes
2021-05-28T02:44:15.661448Z 0 [Note] InnoDB: GCC builtin __atomic_thread_fence() is used for memory barrier
2021-05-28T02:44:15.661484Z 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
2021-05-28T02:44:15.661554Z 0 [Note] InnoDB: Adjusting innodb_buffer_pool_instances from 8 to 1 since innodb_buffer_pool_size is less than 1024 MiB
2021-05-28T02:44:15.665253Z 0 [Note] InnoDB: Number of pools: 1
2021-05-28T02:44:15.666858Z 0 [Note] InnoDB: Using CPU crc32 instructions
2021-05-28T02:44:15.668719Z 0 [Note] InnoDB: Initializing buffer pool, total size = 128M, instances = 1, chunk size = 128M
2021-05-28T02:44:15.682815Z 0 [Note] InnoDB: Completed initialization of buffer pool
2021-05-28T02:44:15.704828Z 0 [Note] InnoDB: Highest supported file format is Barracuda.
2021-05-28T02:44:15.740351Z 0 [Note] InnoDB: Creating shared tablespace for temporary tables
2021-05-28T02:44:15.740508Z 0 [Note] InnoDB: Setting file './ibtmp1' size to 12 MB. Physically writing the file full; Please wait ...
2021-05-28T02:44:15.749746Z 0 [Note] InnoDB: File './ibtmp1' size is now 12 MB.
2021-05-28T02:44:15.752389Z 0 [Note] InnoDB: 96 redo rollback segment(s) found. 96 redo rollback segment(s) are active.
2021-05-28T02:44:15.752437Z 0 [Note] InnoDB: 32 non-redo rollback segment(s) are active.
2021-05-28T02:44:15.753137Z 0 [Note] InnoDB: Waiting for purge to start
2021-05-28T02:44:15.808294Z 0 [Note] InnoDB: 5.7.32 started; log sequence number 115785122
2021-05-28T02:44:15.809081Z 0 [Note] InnoDB: Loading buffer pool(s) from /Library/Application Support/appsolute/MAMP PRO/db/mysql57/ib_buffer_pool
2021-05-28T02:44:15.809923Z 0 [Note] Plugin 'FEDERATED' is disabled.
2021-05-28T02:44:15.810558Z 0 [Note] InnoDB: Buffer pool(s) load completed at 210527 20:44:15
mysqld: Table 'mysql.plugin' doesn't exist
2021-05-28T02:44:15.811319Z 0 [ERROR] Can't open the mysql.plugin table. Please run mysql_upgrade to create it.
2021-05-28T02:44:15.814522Z 0 [Warning] Gtid table is not ready to be used. Table 'mysql.gtid_executed' cannot be opened.
2021-05-28T02:44:15.829022Z 0 [Note] Found ca.pem, server-cert.pem and server-key.pem in data directory. Trying to enable SSL support using them.
2021-05-28T02:44:15.829045Z 0 [Note] Skipping generation of SSL certificates as certificate files are present in data directory.
2021-05-28T02:44:15.835171Z 0 [Warning] CA certificate ca.pem is self signed.
2021-05-28T02:44:15.835846Z 0 [Note] Skipping generation of RSA key pair as key files are present in data directory.
2021-05-28T02:44:15.836289Z 0 [Note] Server hostname (bind-address): '127.0.0.1'; port: 8889
2021-05-28T02:44:15.837317Z 0 [Note] - '127.0.0.1' resolves to '127.0.0.1';
2021-05-28T02:44:15.837404Z 0 [Note] Server socket created on IP: '127.0.0.1'.
2021-05-28T02:44:15.838541Z 0 [Warning] Insecure configuration for --pid-file: Location '/Applications/MAMP/tmp' in the path is accessible to all OS users. Consider choosing a different directory.
2021-05-28T02:44:15.839122Z 0 [Warning] Failed to open optimizer cost constant tables
2021-05-28T02:44:15.839309Z 0 [ERROR] Fatal error: Can't open and lock privilege tables: Table 'mysql.user' doesn't exist
2021-05-28T02:44:15.839607Z 0 [ERROR] Fatal error: Failed to initialize ACL/grant/time zones structures or failed to remove temporary table files.
2021-05-28T02:44:15.839706Z 0 [ERROR] Aborting
2021-05-28T02:44:15.839738Z 0 [Note] Binlog end
2021-05-28T02:44:15.840043Z 0 [Note] Shutting down plugin 'ngram'
2021-05-28T02:44:15.840052Z 0 [Note] Shutting down plugin 'partition'
2021-05-28T02:44:15.840058Z 0 [Note] Shutting down plugin 'BLACKHOLE'
2021-05-28T02:44:15.840062Z 0 [Note] Shutting down plugin 'ARCHIVE'
2021-05-28T02:44:15.840065Z 0 [Note] Shutting down plugin 'PERFORMANCE_SCHEMA'
2021-05-28T02:44:15.840099Z 0 [Note] Shutting down plugin 'MRG_MYISAM'
2021-05-28T02:44:15.840104Z 0 [Note] Shutting down plugin 'MyISAM'
2021-05-28T02:44:15.840310Z 0 [Note] Shutting down plugin 'INNODB_SYS_VIRTUAL'
2021-05-28T02:44:15.840319Z 0 [Note] Shutting down plugin 'INNODB_SYS_DATAFILES'
2021-05-28T02:44:15.840323Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESPACES'
2021-05-28T02:44:15.840326Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN_COLS'
2021-05-28T02:44:15.840328Z 0 [Note] Shutting down plugin 'INNODB_SYS_FOREIGN'
2021-05-28T02:44:15.840332Z 0 [Note] Shutting down plugin 'INNODB_SYS_FIELDS'
2021-05-28T02:44:15.840334Z 0 [Note] Shutting down plugin 'INNODB_SYS_COLUMNS'
2021-05-28T02:44:15.840337Z 0 [Note] Shutting down plugin 'INNODB_SYS_INDEXES'
2021-05-28T02:44:15.840340Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLESTATS'
2021-05-28T02:44:15.840343Z 0 [Note] Shutting down plugin 'INNODB_SYS_TABLES'
2021-05-28T02:44:15.840346Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_TABLE'
2021-05-28T02:44:15.840348Z 0 [Note] Shutting down plugin 'INNODB_FT_INDEX_CACHE'
2021-05-28T02:44:15.840351Z 0 [Note] Shutting down plugin 'INNODB_FT_CONFIG'
2021-05-28T02:44:15.840354Z 0 [Note] Shutting down plugin 'INNODB_FT_BEING_DELETED'
2021-05-28T02:44:15.840357Z 0 [Note] Shutting down plugin 'INNODB_FT_DELETED'
2021-05-28T02:44:15.840359Z 0 [Note] Shutting down plugin 'INNODB_FT_DEFAULT_STOPWORD'
2021-05-28T02:44:15.840361Z 0 [Note] Shutting down plugin 'INNODB_METRICS'
2021-05-28T02:44:15.840364Z 0 [Note] Shutting down plugin 'INNODB_TEMP_TABLE_INFO'
2021-05-28T02:44:15.840366Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_POOL_STATS'
2021-05-28T02:44:15.840369Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE_LRU'
2021-05-28T02:44:15.840371Z 0 [Note] Shutting down plugin 'INNODB_BUFFER_PAGE'
2021-05-28T02:44:15.840373Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX_RESET'
2021-05-28T02:44:15.840376Z 0 [Note] Shutting down plugin 'INNODB_CMP_PER_INDEX'
2021-05-28T02:44:15.840378Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM_RESET'
2021-05-28T02:44:15.840380Z 0 [Note] Shutting down plugin 'INNODB_CMPMEM'
2021-05-28T02:44:15.840383Z 0 [Note] Shutting down plugin 'INNODB_CMP_RESET'
2021-05-28T02:44:15.840385Z 0 [Note] Shutting down plugin 'INNODB_CMP'
2021-05-28T02:44:15.840388Z 0 [Note] Shutting down plugin 'INNODB_LOCK_WAITS'
2021-05-28T02:44:15.840390Z 0 [Note] Shutting down plugin 'INNODB_LOCKS'
2021-05-28T02:44:15.840392Z 0 [Note] Shutting down plugin 'INNODB_TRX'
2021-05-28T02:44:15.840395Z 0 [Note] Shutting down plugin 'InnoDB'
2021-05-28T02:44:15.840578Z 0 [Note] InnoDB: FTS optimize thread exiting.
2021-05-28T02:44:15.840606Z 0 [Note] InnoDB: Starting shutdown...
2021-05-28T02:44:15.945943Z 0 [Note] InnoDB: Dumping buffer pool(s) to /Library/Application Support/appsolute/MAMP PRO/db/mysql57/ib_buffer_pool
2021-05-28T02:44:15.946629Z 0 [Note] InnoDB: Buffer pool(s) dump completed at 210527 20:44:15
2021-05-28T02:44:17.203798Z 0 [Note] InnoDB: Shutdown completed; log sequence number 115785141
2021-05-28T02:44:17.204439Z 0 [Note] InnoDB: Removed temporary tablespace data file: "ibtmp1"
2021-05-28T02:44:17.204501Z 0 [Note] Shutting down plugin 'MEMORY'
2021-05-28T02:44:17.204547Z 0 [Note] Shutting down plugin 'CSV'
2021-05-28T02:44:17.204555Z 0 [Note] Shutting down plugin 'sha256_password'
2021-05-28T02:44:17.204558Z 0 [Note] Shutting down plugin 'mysql_native_password'
2021-05-28T02:44:17.204731Z 0 [Note] Shutting down plugin 'binlog'
2021-05-28T02:44:17.205683Z 0 [Note] /Applications/MAMP/Library/bin/mysqld: Shutdown complete
2021-05-28T02:44:17.6NZ mysqld_safe mysqld from pid file /Applications/MAMP/tmp/mysql/mysql.pid ended
