MAMP Pro & MySQL 8.0?
Discussion around features, enhancements, or anything else MAMP & MAMP Pro users would like to see down the road.
andytela
Re: MAMP Pro & MySQL 8.0?
Post by andytela »
paurray wrote: Thu Nov 09, 2023 10:25 am Are there any “half way idiot proof” instructions online how to get PHP 8 + working with MAMP 6.8.1
I used brew to install it
https://blog.akasu.de/blog/mysql-8-or-m ... mp-pro-6-x
Set my MySQL port in MAMP to 3307 so theres no conflict
Then in your wp-config just use this
define( 'DB_HOST', '127.0.0.1:3306' );
Chacapamac
Post by Chacapamac »
How to use this for other CMS than WP, How to make it work with Joomla?
paurray
Post by paurray »
Thanks for posting this suggestion. Just saw it now. Will need to put my thinking cap and do some tinkering.
Also looking at the Joomla path!
Off the top of my head I guess that this workflow is just plugging MAMP into another MySQL data base management system that is not “managed/maintained” inside MAMP. And that once the connection has been made/re routed it should be business as usual inside MAMP just with a working up to date version of MySQL with Wordpress, Joomla what ever?
Pixel
Post by Pixel »
I am just moving over to Laravel Herd for local Server and DBEngin for local database.
https://herd.laravel.com/ + https://dbngin.com/
Both are free in the basic versions which should cover most of the needs if you want to develop for WP or Joomla locally. The setup is straightforward, even if a little less convenient, simply because mamp came with everything in one package.
There are tutorials on how to setup a simple environment with php + mysql + phpmyadmin. you should be ready to switch in 1 hours max.
paurray
Post by paurray »
This really helped me
Really like Herd but still on the fence. Not really doing any of this on a pro level more like semi pro :D
jerome@64
Post by jerome@64 »
andytela wrote: Thu Jan 04, 2024 10:43 am
Hi everyone,
I would like to install Moodle which requires the installation of MAMP...
I am looking for a solution to make MAMP work with mysql version 8.
I have just carried out the previous actions recommended by Andytela, but I cannot carry out this action :
"Then in your wp-config just use this
define('DB_HOST', '127.0.0.1:3306');
or to you have a new solution ?
thank you for your help
