WP Duplicator PRO
rlmcculley
WP Duplicator PRO
There is very little said in the forum about WP Duplicator PRO. I installed MAMP earlier in the week because it was highly recommended over WAMP / XAMPP.
After installing it everything appeared to work correctly so I place my Duplicator ZIP and accompanying installer.php in the document root directory. When I set up up to run localhost/newsharoniowa2025/ the directory appears as Index of /newsharoniowa2025 with the zip file and the installer.php file. When I use localhost/newsharoniowa2025/installer.php I receive the following error message:
This page isn’t working
localhost is currently unable to handle this request.
HTTP ERROR 500
What needs to happen for this to run my installer.php request on a Windows 11 machine?
HTTP ERROR 500
rlmcculley
Re: WP Duplicator PRO
Laying Duplicator Pro aside -
I copied a full WordPress site into the Document Root, but I still cannot access it through MAMP. I received the same error -
HTTP ERROR 500
That leads me believe that there is a setup issue with my installation of MAMP. I have uninstalled/reinstalled it several times and have had no success it access my development WordPress site.
Any ideas what may be causing this error?
HTTP ERROR 500
rlmcculley
Looking at my wp-config file there is the following error message:
[03-Feb-2025 06:55:20 Etc/GMT+6] PHP Warning: Unknown: Failed to open stream: No such file or directory in Unknown on line 0
[03-Feb-2025 06:55:20 Etc/GMT+6] PHP Fatal error: Failed opening required 'C:/Users/rlmcc/OneDrive/htdocs/newsharoniowa2025/index.php' (include_path='.;C:\php\pear') in Unknown on line 0
rlmcculley
Issue has been resolved -
I was using ONEDRIVE for my htdocs folder and when I moved the folder to DROPBOX everything began working correctly.
