How to enable remoteip Apache module in MAMP Pro
Discussion for guides including MAMP official & unofficial documentation. User submitted guides can be moved here by moderators.
For services like Cloudflare, you may want to see actual IP addresses of clients hitting your sites in your Apache access logs (not cloudflare proxy IP's.) To do this, you need to enable remoteip Apache module and confgiure the trusted proxy addresses.
Per Apache:
This module is used to treat the useragent which initiated the request as the originating useragent as identified by httpd for the purposes of authorization and logging, even where that useragent is behind a load balancer, front end server, or proxy server.
1. In MAMP Pro, enable remoteip_module in Apache.
Mamp Pro Remote Ip Apache
Mamp Pro Remote Ip Apache (89.9 KiB) Viewed 112454 times
2. Open httpd.conf template.
Mamp Pro Apache Httpd Conf
Mamp Pro Apache Httpd Conf (101.77 KiB) Viewed 112454 times
3. Update your LogFormat log replacing %h with %a. (this will show client IP address of the request in log files) Example:
LogFormat "%a %l %u %t \"%r\" %>s %O \"%{Referer}i\" \"%{User-Agent}i\"" combined
4. Configure your trust proxy addresses accordingly.
RemoteIPHeader CF-Connecting-IP
RemoteIPTrustedProxy 192.0.2.1 (example IP address)
RemoteIPTrustedProxy 192.0.2.2 (example IP address)
Mamp Pro Apache Trusted Ip Proxy Address
Mamp Pro Apache Trusted Ip Proxy Address (133.05 KiB) Viewed 112454 times
5. Restart MAMP Pro (Apache).
