I've seen how to install any PHP version, but not how to uninstall one. I had PHP 7.4.21, I then discovered how to install 7.4.27, but I'm not seeing how to uninstall 7.4.21.
Also, I'm hoping uninstalling that won't dereference anything I need, but considering I'd rather use the newer version anyway, I may need to know how to fix any references that MAMP changed that it won't change to the new one.
Any hope/help here?
How to uninstall old PHP versions?
- Attachments
- PHP Versions 7.4 (27.06 KiB) Viewed 18820 times
Re: How to uninstall old PHP versions?
There's no "-" button outside and next to that drop down?
Aha! Thank you. I missed that that's what those are for. I'm not good at barely-noticeable cryptic icons that require assumptions I guess, I figured the option would be in the same menu as the list showing uninstalled PHP versions in Check for Updates
