Problem with Let's Encrypt Certificates
Posted: Sat Dec 04, 2021 10:04 pm
Is anyone else having problems with using Let's Encrypt CA certificates with Apache using MAMP PRO. Every time I configure a new host and select a valid set of Let's Encrypt Certificates, Apache fails to start with the following error: AH01903: Failed to configure CA certificate chain!
After much trial and error I figured out that if I reinstall MAMP PRO, the host that I configured before with the SSL certificates works fine and Apache starts without problems.
Any ideas how to fix this without having to reinstall MAMP every time I add/change SSL configuration for a host?
