ERROR 1100 (HY000) at line 570: Table 'table_name' was not locked with LOCK TABLES
I did a SQL dump from MAMP Pro (dumped all db's into a single file) then tried re-importing but I found when it took the dump it inserted a table lock statement. Now, none of the db's will import and I'm stuck with this message:
