MAMP: Let's Encrypt Auto Renew SSL Crontab Job - Mac OS X
Discussion for guides including MAMP official & unofficial documentation. User submitted guides can be moved here by moderators.
If you use Let's Encrypt SSL certificates for MAMP, you can create a crontab to automatically check your domains for SSL renewals. Below, we create a crontab that will check at 1:15am each morning.
1. Open Terminal.
2. Type
sudo crontab -e
3. Hit "i" and then type
15 1 * * * /usr/local/bin/certbot renew --quiet
4. Type
:wq
to save the crontab job.
Some users are reporting that even though this job will automatically check for SSL renewal updates each day, you need to manually restart APACHE if a new SSL is renewed in order to apply the latest SSL certificate to your website host (if you are mapping SSL's using the LIVE alias').
