Leaving mamp / lack of support
MAMP, while having been useful in the past, is now on its last legs with me.
Having no ability to upgrade/update MySQL and leaving us all in the dust with MySQL 5 when it is 8 that is used, makes this platform nearly unusable.
Sticking developers in this hole has made my work reconsider using MAMP Pro. Along with its nearly useless support that regurgitates old/out dated solutions that do not work, and its lengthy time wasted waiting for a response from support that still ultimately ends up with non-viable solutions, we're done.
Re: Leaving mamp / lack of support
I share your frustrations. Have you found a better or equal alternative for macOS?
I posted this under another forum but thought I would add my 2c worth as I am in the same boat. I could not find another MAMP Mac solution worthwhile and MAMP PRO does have some really useful features so I will be sticking with it but I made a plan with the MySQL 8 issue. I recently started using Laravel and the app requires MySQL 8 so I used a Docker container and it works fine. Keeps it really simple and runs in its own container and doesn't affect the host.
I ran the following commands below to create the container, then used DBeaver to login and setup DB users and import a database and voila. All running smooth. This command maps port incoming port 3307 to the docker container image so it won't cause a conflict if your MySQL is running on 3306. To backup the DB just dump it.
docker pull mysql:8.4
docker run --name mysql8.4 -e MYSQL_ROOT_PASSWORD=root -d -p 3307:3306 mysql:8.4
Not the most ideal solution but it's quick and easy and it works and you can basically install any database you need.
I'm a long-time MAMP user and have found it to be very useful. Regretfully, I have to agree that MAMP support is dreadful, and if their product quality is as poor as their customer service then MAMP Pro 7 will be awful.
I recently submitted a ticket, and their response was, "It should support that but you may consider changing the pHp version along with configuration changes to enable it." That was their entire response. I was surprised by this lack of interest and lack of effort.
When I asked for more information (e.g., change what?) it took them 10 days to respond, and only after I contacted appsolute thinking they were still the parent company for MAMP.
Eventually I was told that they (MAMP) can use the feature on their end and that they could not reproduce my problem. They suggested that I change a few items in the configs (these changes did not work). They then said that the feature doesn't work on their end and will not be fixed in version 7 (coming soon).
It has been over three weeks since their last response and they will not answer or even acknowledge my questions or contact requests.
I'm hoping to find a replacement for MAMP just on principal. My concern is that their lack of respect for their paying customers doesn't stop at customer service, and continues into development and QA.
WSG
WSG
I've actually had decent experiences with MAMP support. They've usually responded to my tickets within a week and a couple of the times my issue got fixed.
This most recent time I reported having MAMP 7 freeze continuously anytime I touched MySQL requiring me to execute a kill all on MySQL processes from the command line. I got a reply a few days later telling me to download the just released MAMP 7.1 which should fix my issues. It did.
I had been think of going to something else for some time though. I really got tired of MAMP 6 freezing on me all the time and having to be force quit. Even though I just bought my upgrade to MAMP PRO 7, I am going to start transitioning some of my sites to Docker-ized containers, but only some of them.
The most resource intensive ones will get the Docker treatment. I have tons of small beans that are going to be fine with just the basics and those are staying in MAMP.
MAMP 7 has MySQL 8.0.35. Also, the current MAMP version is 7.1.3, and the updates are coming quite frequently. Definitely, MAMP is not a dead or neglected project.I feel you, I've also struggled with MAMP being stuck on MySQL 5.
That's not really good enough when you've paid for a product/service.hyperlinked wrote: Wed Oct 09, 2024 2:41 amThey've usually responded to my tickets within a week and a couple of the times my issue got fixed.
