Registrations: Open.
Please register here.
MAMP / MAMP Pro: Disable MySQL Strict Mode
Discussion for guides including MAMP official & unofficial documentation. User submitted guides can be moved here by moderators.
User avatar
MySQL 'Strict Mode' is a new feature in 5.7.
Strict mode controls how MySQL handles invalid or missing values in data-change statements such as INSERT or UPDATE. A value can be invalid for several reasons. For example, it might have the wrong data type for the column, or it might be out of range. A value is missing when a new row to be inserted does not contain a value for a non-NULL column that has no explicit DEFAULT clause in its definition. (For a NULL column, NULL is inserted if the value is missing.) Strict mode also affects DDL statements such as CREATE TABLE.
Disable MySQL Strict Mode MAMP PRO
1. In MAMP Pro, go to File -> Edit Template -> MySQL (my.cnf) -> (your version)
2. Find
[mysqld]
3. Add the following line immediately below [mysqld]:
sql_mode=""
4. Save your my.cnf file and restart MySQL.
Disable MySQL Strict Mode MAMP (Free)
1. Quit MAMP.
2. Run following command in the Terminal:
touch /Applications/MAMP/conf/my.cnf && open -t /Applications/MAMP/conf/my.cnf
3. When this file is empty, then add the following below. If the file is not empty, then simply add the line sql_mode="" right after the line [mysqld]
[mysqld]
sql_mode=""
4. Save the config file and close the text editor; restart MAMP and start the servers.
te3d
Re: MAMP / MAMP Pro: Disable MySQL Strict Mode
Post by te3d »
Thanks - I was just hired to upgrade an old ExpressionEngine 2 site and ran into this error when trying to get my local development environment set up in MAMP. This got me up and running quickly. Much appreciated.
Te3d
